ER32 precision collet holders. 3 morse taper with a 12mm draw bar thread.
ER collets have the unique ability to grip over a diameter range of 1mm without any loss of accuracy. This flexibility means that you need fewer collets compared to other collet-based systems. An additional benefit is that there is no requirement for a separate imperial listing; a 1/4 end mill, for example, will fit into the 7mm to 6mm collet.
ER Collet Series ER32 Web Attribute Set: Milling Machines Taper: 3MT
EAN Barcode 5052511044184
