{"product_id":"axminster-engineer-series-machine-coolant-pump-system","title":"Axminster Engineer Series Machine Coolant Pump System","description":"\u003cp\u003eThe Axminster Machine Coolant System consists of a 9 litre tank and a 95W 230V electric pump. Supplied as a complete kit, it also includes a flexible discharge hose and nozzle, 2m delivery hose pipe, 1m return hose, shut off valve and mounting bracket and fixings.\u003c\/p\u003e\u003cp\u003eThe unit is easy to retrofit to an existing machine. It is relatively small, so should not present any problems finding a convenient location. It will fit inside a lathe cabinet, under the bench, wherever you like, bear in mind you will need to top it up and clean it out occasionally.\u003c\/p\u003e\u003cp\u003eThe Axminster Machine Coolant Pump System is suitable for use with drilling\/milling machines, small lathes, metal cutting bandsaws, etc. The waste sieve filters swarf and is easy to remove and clean.  The tank has a mid baffle, which prevents sediment reaching the pump unit.\u003c\/p\u003e\u003cp\u003eSupplied with an inline switch, cable and fitted with 13A BS plug.  390mm long, 270mm deep and 320mm high.\u003c\/p\u003e","brand":"Axminster","offers":[{"title":"Default Title","offer_id":54118308348251,"sku":"104941","price":189.18,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/104941_xl.jpg?v=1789774828","url":"https:\/\/www.axminstertools.com\/products\/axminster-engineer-series-machine-coolant-pump-system","provider":"Axminster Tools","version":"1.0","type":"link"}
