{"product_id":"axminster-engineer-series-scriber-block","title":"Axminster Engineer Series Scriber Block","description":"\u003cp\u003eBase dimensions 80 x 63mm, spindle length 300mm, scriber length 175mm. A basic tool for machinists and toolmakers, it is used for accurately scribing lines, transferring measurements or probing surfaces in inspection work. A fully hardened and ground base serves as an accurate reference surface. A machined Vee groove in the base allows the gauge to be used on curved surfaces. A Vee groove at the front end lets the spindle adjust to any angle above or below the base, allowing it to be used both as a height gauge and a depth gauge. Two retractable pins allow the gauge to be located against the edge of a surface plate or T-slot for linear work. A 1\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e (6.35 mm) hole in the spring loaded scriber holder allows a dial indicator to be attached for checking flatness, parallelism, heights, depths etc. Grooves on the side of the base give a comfortable grip. Well tapered scriber for better sighting while working. The scriber is hardened to RC55-60 and is tapered for a good view of the work.\u003c\/p\u003e","brand":"Axminster","offers":[{"title":"Default Title","offer_id":54116016456027,"sku":"220091","price":23.18,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/220091_xl.jpg?v=1789759346","url":"https:\/\/www.axminstertools.com\/products\/axminster-engineer-series-scriber-block","provider":"Axminster Tools","version":"1.0","type":"link"}
