{"product_id":"axminster-engineers-squares","title":"Axminster Engineer's Squares","description":"\u003cp\u003eAn engineer's square gives you four 90° angles: internal, external, outside blade to inside stock and inside blade to outside stock. Compare this to a carpenter's try square which only guarantees accuracy on the internal angle. Our engineer's squares comprise a stainless steel blade, triple riveted into a steel stock. The hardened and tempered blade and the high quality steel stock are ground and polished for accuracy. Final polishing makes the rivets virtually invisible. Axminster Professional Engineer's squares conform to DIN875\/II, guaranteed square and straight. The small notch on the inside corner of the square prevents accumulations of dust and dirt, small burrs or saw whiskers on the workpiece affecting the accuracy of the reading. Supplied in a foam lined case.\u003cstyle id=\"1\" type=\"2\"\u003e \u003c\/style\u003eN.B The blade measurements given are the inner length of the blade.\u003c\/p\u003e\u003cp\u003e80mm inside edge, 100mm outside edge\u003c\/p\u003e\u003cp\u003e130mm inside edge, 150mm outside edge\u003c\/p\u003e\u003cp\u003e225mm inside edge, 255mm outside edge\u003c\/p\u003e","brand":"Axminster","offers":[{"title":"50 mm","offer_id":54115921985883,"sku":"900113","price":3.98,"currency_code":"GBP","in_stock":false},{"title":"75 mm","offer_id":54115922018651,"sku":"900114","price":3.98,"currency_code":"GBP","in_stock":false},{"title":"100 mm","offer_id":54115922051419,"sku":"900115","price":4.18,"currency_code":"GBP","in_stock":true},{"title":"150 mm","offer_id":54115922084187,"sku":"900116","price":5.78,"currency_code":"GBP","in_stock":false},{"title":"80 mm","offer_id":54118194053467,"sku":"102457","price":9.48,"currency_code":"GBP","in_stock":true},{"title":"130 mm","offer_id":54118194086235,"sku":"102461","price":12.98,"currency_code":"GBP","in_stock":true},{"title":"225 mm","offer_id":54118194119003,"sku":"102463","price":19.58,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/900113_xl.jpg?v=1789758302","url":"https:\/\/www.axminstertools.com\/products\/axminster-engineers-squares","provider":"Axminster Tools","version":"1.0","type":"link"}
