Axminster Engineer's Squares
SKU: 900115
£4.18
£3.48 Excl. VAT
  • General duty steel squares
  • Hardened steel blades
  • Intended for sheet metal use but also popular with cabinet makers
  • Holds its accuracy over a long period of time
  • Accurate on both inside and outside edges
An engineer's square gives you four 90° angles: internal, external, outside blade to inside stock and inside blade to outside stock. Compare this to a carpenter's try square which only guarantees accuracy on the internal angle. Our engineer's squares comprise a stainless steel blade, triple riveted into a steel stock. The hardened and tempered blade and the high quality steel stock are ground and polished for accuracy. Final polishing makes the rivets virtually invisible. Axminster Professional Engineer's squares conform to DIN875/II, guaranteed square and straight. The small notch on the inside corner of the square prevents accumulations of dust and dirt, small burrs or saw whiskers on the workpiece affecting the accuracy of the reading. Supplied in a foam lined case.N.B The blade measurements given are the inner length of the blade.
80mm inside edge, 100mm outside edge
130mm inside edge, 150mm outside edge
225mm inside edge, 255mm outside edge
Blade Length 100 mm
Size 4
Web Attribute Set Engineers Squares
EAN Barcode 5052511042746
