The Axminster Professional Flat Squares are precision tools available in two sizes: 100 x 63 mm and 150 x 100 mm. Made from hardened and tempered stainless steel with a satin chrome-plated finish, these flat squares feature metric graduations and are ideal for setting up tools, aligning blades, and ensuring parts are properly positioned.
Each edge of the Axminster Professional Flat Squares is meticulously ground to ensure they are straight and parallel. This attention to detail makes them perfect for tasks that require exact measurements and alignment. Whether you are working on intricate woodworking projects or precise metal fabrication, these flat squares will help you achieve the accuracy you need.
These flat squares comply with EEC-I standards, ensuring top-notch quality and reliability. Their robust construction and practical design make them a valuable addition to any professional's toolkit.
Blade Length 100 mm
Web Attribute Set Squares
EAN Barcode 5052511134717
