This granite plate is made of solid granite, offering many advantages compared to cast iron. Granite is the perfect material for surface plates, being inherently stable and wear resistant. Unlike cast iron, granite does not rust or corrode. It is non-magnetic and non-conductive. All this makes it an excellent base for accurate marking out.
The plate is Grade 1, 300mm x 300mm x 50mm thick. It is ideal wherever there is a requirement for an accurate flat surface, for measuring, setting or checking. Use it in conjunction with a suitable abrasive for lapping and sharpening tools.
Overall L x W x H 300 mm x 300 mm x 50mm
Additional Accessories No
Web Attribute Set Surface Plates
EAN Barcode 5052511109661
