{"product_id":"axminster-honing-bevel-guide-package","title":"Axminster Honing \u0026 Bevel Guide Package","description":"\u003cp\u003eThis combination of the Ultimate Edge Honing Guide with the Bevel Guide makes a hand sharpening and honing guide that is perfect for plane blades and chisels etc. The two together allow you to sharpen your blades with very precise bevel angles and edges square to the sides.\u003c\/p\u003e\u003cp\u003eBoth parts are precision made on CNC machines in Axminster’s own manufacturing facility.\u003c\/p\u003e\u003cp\u003eThe unique feature of this combination is the high level of accuracy and control it offers. Using a bench or diamond stone, you can sharpen all your chisels and bench plane blades with the bevel angle of your choice from a shallow 20\u003cspecial id=\"8\"\u003e\u003c\/special\u003e to a steep 40\u003cspecial id=\"8\"\u003e\u003c\/special\u003e. After establishing the primary bevel, you can add a micro bevel from as little as 1\u003cspecial id=\"8\"\u003e\u003c\/special\u003e.\u003c\/p\u003e\u003cp\u003eIt is perfect for plane blades, bevel edge, mortice and Japanese chisels. The jaws are a slightly undercut dovetail to ensure secure clamping of a blade or chisel against the body. The jaws can accommodate blades or chisels from 6mm to 66mm wide. The left-hand jaw is reversible, one side straight and the other slightly curved enabling you to clamp chisels with unparallel sides equally securely.\u003c\/p\u003e\u003cp\u003eSet-up could not be easier, based on a blade projection of 25mm, the guide includes a small setting jig.  The degree scale is clear and easy to read with the markings permanently etched. The wide roller ensures perfect stability and at the same time prevents undue stone wear.\u003c\/p\u003e\u003cp\u003eThis guide can accommodate a wide variety of blades in a wide range of sizes and guarantees precise results every time.\u003c\/p\u003e","brand":"Axminster Professional","offers":[{"title":"Default Title","offer_id":54228244103515,"sku":"720842","price":130.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/720842_xl.jpg?v=1790856334","url":"https:\/\/www.axminstertools.com\/products\/axminster-honing-bevel-guide-package","provider":"Axminster Tools","version":"1.0","type":"link"}
