High quality, HSS Co8 drill bits made to DIN388, with a long life as they have a TiN coating. The wide flute design is ideal for good chip evacuation and the point is designed to maximise self-centring. They can be used on a wide range materials including cast steel alloyed and non-alloyed, grey cast iron, graphite, malleable cast iron and woods. When used with cutting fluids, will drill stainless steels and titanium.
Drill Bit Diameter 6.8 mm
Overall Length \ Working Length 109 mm 69 mm
L1 69mm L2: 109mm Drill Bit Dimensions: L1 69 mm L2 109 mm Web Attribute Set: Drill Bits
EAN Barcode 5052511106905
