This floor stand is for the Axminster Workshop AW355WL and Axminster Professional AP530WL and AP370WL woodturning lathes.
Made from box section steel, it is simple to assemble and sturdy enough to hold this lathe securely. It's adjustable in height from 610mm-875mm and so creates a comfortable working height. The feet are splayed back to give plenty of foot space, and are fitted with rubber feet which are adjustable to accommodate an uneven workshop floor.
This stand is also adjustable in length between 590mm-945mm which means it could fits many other lathes that are normally bench mounted. You would possibly either need to fabricate some suitable mounting plates or drill suitably spaced holes to be able to attach your lathe. Recommended maximum weight 70kg.
