{"product_id":"axminster-led-stayput-strip-light","title":"Axminster LED Stayput Strip Light","description":"\u003cp\u003eThis LED work light would be perfect for detailed bench work. It has a 'stayput' flexible arm with a 300mm 14W LED strip light mounted on the end. The head can be placed exactly where you need it, plus the lamp output can be varied using the brightness adjuster dial with a range of 10-100%. Being LED there is almost no heat generated; a poly carbonate shield protects the LED's. A 1.8m cable and 13A plug are fitted. The arm is 500mm long and the base has four holes spaced at 60mm for mounting on the bench. There is also the choice of three optional mounting brackets (sold separately), an angle plate, screw clamp and magnetic mounts. Ideal for use in the workshop, assembly bench or in the office. The work light has 72 LEDs.\u003c\/p\u003e","brand":"Axminster","offers":[{"title":"Default Title","offer_id":54117966512475,"sku":"101386","price":109.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/101386_xl.jpg?v=1789770825","url":"https:\/\/www.axminstertools.com\/products\/axminster-led-stayput-strip-light","provider":"Axminster Tools","version":"1.0","type":"link"}
