The Axminster Professional Lifting Jax is a versatile and essential tool for both on-site and at-home use. With the capability to lift up to 150kgs to a height of 225mm, it is perfect for a wide range of tasks where an extra pair of hands is needed. Whether you are fitting decking, installing a door, or levelling a freezer, the Lifting Jax makes the job easier and more efficient. Its enclosed aluminium body, carbon steel bar, and high-grade steel lifting pads ensure durability and reliability, making it a must-have addition to any tool kit.
Designed for convenience and ease of use, the Lifting Jax is ideal for professionals and ad hoc use. Its robust construction and high lifting capacity make it suitable for various applications, providing the support you need for precise and safe handling of heavy items. The Lifting Jax is not only practical but also built to last, offering a dependable solution for your lifting needs. Whether you are a professional tradesperson or a DIY enthusiast, the Axminster Professional Lifting Jax is an invaluable tool that will enhance your productivity and efficiency.
Web Attribute Set Door Clamps
EAN Barcode 5052511136193
