This Axminster Magnetic Hose Coupler Kit provides a simple way to expand an existing magnetic dust extraction system by adding magnetic connection points to additional machines. Designed for workshops using both 63mm and 100mm extraction, it allows more machines to be prepared for quick hose changes, reducing the time spent reconnecting dust extraction and helping maintain an efficient workflow. The self-aligning connection provides a secure fit while allowing the hose to be released quickly when moving between machines.
The kit contains one 100mm male coupler, two 63mm female steel-ring couplers, two 63mm rubber cuffs, one 63mm retaining clip, three 100mm female steel-ring couplers, three 100mm rubber cuffs and one 100mm retaining clip. Manufactured from durable workshop-grade materials, the components are designed for reliable everyday use and install easily onto compatible machines using the supplied rubber cuffs, creating additional magnetic connection points throughout the workshop.
Designed by Axminster for practical workshop use, this kit offers a straightforward way to extend a magnetic dust extraction system across a wider range of machines. Suitable for professional workshops and home woodworkers alike, it helps make dust extraction connections quicker, more convenient and easier to manage.
EAN Barcode 5052511147045
