{"product_id":"axminster-mitre-fence-for-19mm-slots","title":"Axminster Mitre Fence For 19mm Slots","description":"\u003cp\u003eThis mitre fence has a solid steel bar 19mm x 9.5mm (3\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e x 3\/8\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) and 320mm long. It will fit onto any machine or router table with a similar size groove. Installation is simple and you can make the bar a perfect fit in your mitre slot. The bar has a removable locking washer at one end for T-slot grooves. If you have a plain slot, just unscrew the washer. Along the side of the bar, three adjustable grub screws, allow you to remove any play between the bar and groove for smooth, accurate operation. Once set up in your machine’s slot, it will allow you to cut accurate mitres every time.\u003c\/p\u003e\u003cp\u003eThis quadrant is 5mm anodised aluminium plate featuring positive stops at 0\u003cspecial id=\"8\"\u003e\u003c\/special\u003e, 22.5\u003cspecial id=\"8\"\u003e\u003c\/special\u003e, 30\u003cspecial id=\"8\"\u003e\u003c\/special\u003e, 45\u003cspecial id=\"8\"\u003e\u003c\/special\u003e, 60\u003cspecial id=\"8\"\u003e\u003c\/special\u003e, 67.5\u003cspecial id=\"8\"\u003e\u003c\/special\u003e and 90\u003cspecial id=\"8\"\u003e\u003c\/special\u003e. A spring-loaded plunger locks into the indents for rapid adjustment to common angles. The pointer and degree scale allows you to set the quadrant to any other angle between 0\u003cspecial id=\"8\"\u003e\u003c\/special\u003e and 90\u003cspecial id=\"8\"\u003e\u003c\/special\u003e left and right as required.\u003c\/p\u003e","brand":"Axminster","offers":[{"title":"Default Title","offer_id":54118308413787,"sku":"104928","price":46.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/104928_xl.jpg?v=1789774837","url":"https:\/\/www.axminstertools.com\/products\/axminster-mitre-fence-for-19mm-slots","provider":"Axminster Tools","version":"1.0","type":"link"}
