Vertical slide for use on the Axminster SC2 Mini Lathe. This will allow simple milling tasks to be carried out on the lathe. Work can be held onto the slide using the clamp system provided. Milling cutters should be mounted in the headstock, chuck or collet holder.
Axminster Model Engineer Series SC2 Vertical Slide
| Web Attribute Set | Lathe Accessories |
| EAN Barcode | 5052511027392 |
