A stepped ABS hose adaptor with seven different sizes that can form perhaps two or more adaptors. Simply cut the section you require with a fine toothed saw. Diameters are 25mm, 50mm, 63mm, 75mm, 100mm, 125mm and 150mm (sizes stated are outside diameter).
Axminster Multiple Stepped Hose Adaptor
| EAN Barcode | 5052511050291 |
