{"product_id":"axminster-no-69-1-2-block-plane","title":"Axminster No. 69 1\/2 Block Plane","description":"\u003cp\u003eAxminster No. 69 1\/2 Low Angle Block Plane combines the best characteristics of two classic block plane designs into one highly capable and versatile tool. Featuring the low blade angle of a No. 60 1\/2 and the wider blade format of a No. 9 1\/2, it delivers excellent end grain performance while offering greater blade width and stability for general woodworking tasks. Compact enough for one-handed use yet substantial enough for demanding workshop work, it is equally at home trimming, fitting and fine-tuning joinery.\u003c\/p\u003e\u003cp\u003eDesigned for accuracy and ease of use, the No. 69 1\/2 features a robust ductile iron body chosen for its strength, durability and impact resistance. The low 13.5° blade bedding angle allows effortless cutting, particularly on end grain, while the adjustable mouth can be set for either fine finishing cuts or heavier stock removal. A micro-adjustable depth mechanism and lateral blade adjustment provide precise control over blade position, helping achieve fine, even shavings with minimal effort.\u003c\/p\u003e\u003cp\u003eThe sole measures 158mm long and is precision machined for reliable accuracy. The 41mm wide, bevel-up O1 high carbon steel blade offers greater cutting width than a standard No. 60 1\/2, increasing versatility and efficiency across a wide range of woodworking applications. The blade is oil quenched, hardened and tempered to HRC 63 for excellent edge retention and durability. Weighing approximately 950g, the combination of increased mass, wider blade and low cutting angle results in a block plane with exceptional cutting performance and control.\u003c\/p\u003e\u003cp\u003eAxminster woodworking tools are designed to provide dependable performance, lasting quality and excellent value. Built for the needs of both keen enthusiasts and professional makers, they combine proven designs with practical features that enhance workshop productivity.\u003c\/p\u003e\u003cp\u003eIdeal for furniture making, cabinetmaking, joinery, site work and general woodworking, the Axminster No. 69 1\/2 Low Angle Block Plane is an excellent choice for anyone looking for a versatile all-round block plane. Supplied ready for final honing and setup, it requires minimal preparation before use and is equally effective on end grain, edge trimming, fitting tasks and fine finishing work.\u003c\/p\u003e","brand":"Axminster","offers":[{"title":"Default Title","offer_id":54118849610075,"sku":"114254","price":49.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114254_xl.jpg?v=1789793701","url":"https:\/\/www.axminstertools.com\/products\/axminster-no-69-1-2-block-plane","provider":"Axminster Tools","version":"1.0","type":"link"}
