This is a pack of two reusable glue applicators. Ever had trouble getting glue into slots and dowel holes. These double-ended silicone rubber applicators solve the problem. The dowel tip allows you to work the glue into the dowel hole. The biscuit tip tapers to a thin flexible flat end allowing you to apply glue into a biscuit slot with ease. These applicators work with most wood glues, PVA or polyurethane. To clean, either wash with soap and water or let the glue dry and then peel it off, which is more fun.
Axminster Non Stick Dowel & Biscuit Glue Brush
| Web Attribute Set | Glue Applicators |
| EAN Barcode | 5052511123827 |
