The Axminster Professional Parallel Jaw Clamp will find favour in situations where heavy-duty clamps are too weighty and cumbersome. The clamps exert sufficient force holding your work firmly whilst glue cures. The large surface area of the jaws spreads the pressure evenly. A polyamide, glue resistant casing surrounds the jaws. The jaw faces remain parallel across the full width of the clamping area. The heads are reversible so the clamp can also act as a spreader. These are excellent, convenient cramps for light to medium duty applications. 200kg max clamping pressure.
Lifetime guarantee.
Clamping Capacity x Throat 600 x 80 mm
Web Attribute Set F Clamps
EAN Barcode 5052511062393
