This package comprises the Axminster Professional Premium AS Workbench and the Axminster Professional Pro 2 Cupboard.
A traditionally designed beechwood bench equipped with a heavy duty top, tool well at rear and one wooden vice with central screw and twin support bars plus a traditional L shaped tail vice. Built to a very high standard from European beech, the frame members are 40mm by 80mm, the top is a very substantial 50mm thick with 110mm deep edgings and there is a total of 13, 19mm dog holes for clamping longer lengths of timber with the tail vice. The overall width of the working surface is 615mm, including a tool well of 150mm. The end tail vice is 220mm wide and the front vice 520mm, giving plenty of holding width for large pieces of timber. Tool storage is catered for by an underslung drawer, 400mm long. Four 19mm steel bench dogs are provided, two short and two long. The bench is supplied flat packed, so home assembly will be required.
All Axminster workbenches are lacquered top and bottom to help maintain flatness. However, if your workshop is known to get damp, you may need to add more layers of lacquer to help prevent movement.
The Pro 2 Cupboard is intended to fit the Premium benches and gives four drawers and a twin door cupboard. Made from faced chipboard with good quality drawer runners and large beechwood handles. The drawers each have an internal size of 340 x 370 x 80mm deep, whilst the lockable cupboard opens out to 370 width x 520 height x 370mm depth.
Due to environmental factors outside of our control, we cannot warrant or accept returns for timber movement.
Web Attribute Set Woodworking Benches
EAN Barcode 5052511078523
