This extension bed is designed to suit the AW530WL Woodturning Lathe. It increases the distance between centres to 805mm between centres. It is perfect for turning larger projects and workpieces that need the extra capacity. Supplied with fixings bolts and rubber feet to match your lathe.
Axminster Professional
Axminster Professional 300mm Extension Bed
| Web Attribute Set | Woodturning Lathe Bed Extensions |
| EAN Barcode | 5052511136391 |
