The Axminster Professional AP125MB Metal Bandsaw is a versatile, medium-sized machine, ideal for smaller fabrication, maintenance and general engineering tasks.
Built around a rigid cast iron frame and bed, it offers excellent stability while reducing vibration for clean, precise cuts, even through tougher materials. A fully adjustable swivelling head enables accurate mitre cuts from -45° to +60° without repositioning the workpiece, improving both convenience and efficiency.
A 550W motor powers the hydraulic downfeed system, to provide smooth, controlled cutting with variable adjustment. This allows feed rates to be fine-tuned to suit different materials and applications, helping improve cutting efficiency while extending blade life. An automatic downfeed stop further enhances usability, enabling safe, consistent cutting with minimal supervision.
The three speed belt drive can be easily adjusted to suit a variety of metals, from lighter materials to more demanding work. Combined with precision ball bearing blade guides and a high-quality metal cutting blade supplied as standard, the machine delivers dependable cutting accuracy.
Ease of use is further supported by a quick-release material vice and an integrated mobility system, featuring rear-mounted wheels and a pull-out handle. This allows the bandsaw to be moved easily when required, while the robust floor stand provides a stable platform during operation.
Well finished, reliable and practical, the AP125MB Metal Bandsaw has proven to be an excellent medium-sized metal bandsaw for workshop use.
Supplied with a bi-metal blade.
