The Axminster Professional AP1500DE Dust Extractor is a reliable and efficient dust extractor designed for professional use. Built to deliver consistent performance, it combines effective dust collection with features that make day to day operation in a medium sized workshop a breeze.
The machine is powered by a 1,500W motor, and features a balanced steel impeller ensuring long service life and dependable airflow of 1546 m3/hr @ 125mm. The cartridge filter provides fine filtration down to 99% > 1 micron and increases the potential use of the machine to include sanders, as well as saws, planers etc. The hand crank filter paddles allow easy and quick filter changing.
With a bag capacity of 153L, the extractor is fitted with bag clips and quick fit straps for simple bag changes. The main 125mm outlet can be adapted into two 100mm outlets, allowing you to either connect two separate machines or link two extraction ports from a single machine. Larger wheels improve portability, making it easy to move around the workshop as required.
A particular highlight is the time delay switch with remote control. This allows you to leave the extractor running after finishing a task, helping to clear any dust remanence. The remote control makes it possible to switch the unit on and off anywhere in the workshop - even if the extractor is located outside of the working area.
Airflow 1,546 m³/hr @ 125 mm
Filter Performance 99% 1 micron
Overall L x W x H 1035 x 653 x 1795mm
Power 1.5 kW
Rating Frequent Use
Sound Power Level LwA [Uncertainty K] 83 dB(A)
Plug Fitted UK 3 pin plug
Web Attribute Set Coarse Dust & Chippings Extractors
EAN Barcode 5052511142392
