This lightweight, professional nailer/stapler will fire either 18 gauge T-headed nails from 10mm to 30mm long or narrow crown staples in the range of 15mm to 32mm. With low air consumption, it works off the smallest compressors, such as the Senco AC4504 4L Low Noise Oiless Compressor.
It is easy to load and has a re-load sight so that the operator can see when the magazine is empty. Other useful features are the depth adjustment which controls the depth to which the nail is driven, the adjustable air exhaust outlet and the quick release front cover to give easy access for clearing jammed nails.
Supplied with a 1/4 BSP quick release Euro bayonet fitting and a storage case.
Inlet 1/4 BSP
Rating Frequent Use
Web Attribute Set Air Nailers & Staplers
EAN Barcode 5052511124992
