This medium weight, trade-rated nail gun fires 16 gauge T-headed brad nails from 20mm to 50mm in length. With its low air consumption, this nailer can be used with any of the smaller 25-litre capacity compressors. It can be used with standard trigger firing or in bump mode where, with the trigger engaged, a nail is delivered each time the safety stop is depressed, useful for fast fixing.
The gun is easy to load and the handle has a high grip rubber covering. An adjustable exhaust air outlet means that the exhaust can be directed to where convenient.
A 1/4 BSP quick release male Euro bayonet fitting is provided in the back of the tool for direct connection to the airline. Supplied in a plastic storage case.
Inlet 1/4 BSP
Overall L x W x H 315 mm x 85 mm x 280 mm
Rating Frequent Use
Web Attribute Set Air Nailers & Staplers
EAN Barcode 5052511125081
