{"product_id":"axminster-professional-ap2260bs2-belt-sander-230v","title":"Axminster Professional AP2260BS2 Belt Sander - 230V","description":"\u003cp\u003eThis compact belt sander is a well made and relatively simple machine. With a 2.2kW motor driving a 150mm wide belt, it is one of the most useful machines to have in any woodworking workshop. The belt drive has an automatic oscillating action to provide a scratch-free finish and longer abrasive life. The belt also runs on a graphite anti-friction plate. The whole belt platen can tilt through 90° from vertical to horizontal, the precision ground cast iron table being easily adjusted in two planes to suit. The table has a stanadard 3\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e x 3\/8\u003cspecial id=\"1\"\u003e\u003c\/special\u003e mitre slot to take a mitre fence. The dust hood can be rotated to clear the end of the belt for easy belt changing, and also to allow a small table to be mounted for sanding curved work. The stand is made from thick gauge welded steel and had a very useful belt storage cupboard. Smooth running, quiet in use, a very useful finishing machine. Supplied with a 150mm x 2,260mm 80G abrasive belt fitted. We recommend using cloth backed sanding belts on this machine.\u003c\/p\u003e\u003cp\u003eN.B. This Machine requires a 16amp supply and it's recommended that a C Type breaker is used, if you are unsure please contact a qualified electrician.\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003ePlease note, if you require an EU plug, please ensure you purchase 113776\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e","brand":"Axminster Professional","offers":[{"title":"Default Title","offer_id":54118434668891,"sku":"107708","price":899.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/107708_xl.jpg?v=1789779667","url":"https:\/\/www.axminstertools.com\/products\/axminster-professional-ap2260bs2-belt-sander-230v","provider":"Axminster Tools","version":"1.0","type":"link"}
