Axminster Professional
Axminster Professional AP2260BS2 Belt Sander - 230V
SKU: 107708
£899.98
£749.98 Excl. VAT
  • Sands either vertically, horizontally or any angle between
  • Sanding belt oscillates for a scratch-free finish and longer abrasive life
  • Table height adjustment by geared handwheel for precision setting
This compact belt sander is a well made and relatively simple machine. With a 2.2kW motor driving a 150mm wide belt, it is one of the most useful machines to have in any woodworking workshop. The belt drive has an automatic oscillating action to provide a scratch-free finish and longer abrasive life. The belt also runs on a graphite anti-friction plate. The whole belt platen can tilt through 90° from vertical to horizontal, the precision ground cast iron table being easily adjusted in two planes to suit. The table has a stanadard 3/4 x 3/8 mitre slot to take a mitre fence. The dust hood can be rotated to clear the end of the belt for easy belt changing, and also to allow a small table to be mounted for sanding curved work. The stand is made from thick gauge welded steel and had a very useful belt storage cupboard. Smooth running, quiet in use, a very useful finishing machine. Supplied with a 150mm x 2,260mm 80G abrasive belt fitted. We recommend using cloth backed sanding belts on this machine.
N.B. This Machine requires a 16amp supply and it's recommended that a C Type breaker is used, if you are unsure please contact a qualified electrician.
Please note, if you require an EU plug, please ensure you purchase 113776
Belt Speed 960 m/min
Dust Extraction Outlet 100 mm
Overall L x W x H 1,325 mm x 570 mm x 1,235 mm
Power 2.2 kW
Rating Frequent Use
Table Size 750 mm x 250 mm
Min Extraction Airflow Required 1,000 m³/hr
Abrasive Belt Size 150 mm x 2,260 mm
Sound Pressure Level LpA [Uncertainty K] 81 dB(A) [3.0 dB]
Plug Fitted UK 16A Plug
Web Attribute Set Belt Sanding Machines
EAN Barcode 5052511124404
  • UK Mainland - £70
