Upgrade your existing Axminster Professional AP254SB with this versatile table saw extension, designed specifically for older AP254SB models.
This upgrade converts your saw to the twin extension table version, giving you greater flexibility in how your workspace is configured.
Set up one extension table on each side of the saw for a traditional cabinet-making layout, or alternatively, mount both extension tables on the right-hand side to create a large, continuous support surface - ideal for handling wide panels and large workpieces.
The result is improved material control, increased stability, and a setup that adapts to the way you work, without the need to replace your existing saw.
Web Attribute Set Saw Bench Accessories
EAN Barcode 5052511142897
