The Axminster Professional AP25FD Floor Drill is designed to provide a robust and precise drilling experience. Featuring a large cast iron table with a polished finish, it offers a strong and rigid work surface, ensuring stability during use. The spindle runs in genuine NSK ball bearings, which both increases accuracy and minimises vibration – both desirable benefits from a drill. The multi-vee type belts provide maximum grip and low vibration, contributing to an even smoother operation.
Safety is a priority with the AP25FD. The electrically interlocked chuck guard prevents accidental activation, and an integrated belt cover safety switch stops the drill from running when the cover is open. The drill also features an adjustable LED work lamp for enhanced visibility of your workpiece.
With the improved depth stop design, you can make easy adjustments for precise drilling depths. Drill control is smooth and comfortable with the one-piece cast iron handle with soft runner grips. The quality 1-16mm keyless chuck allows for quick and easy changing of drill bits, while the rack and pinion table adjustment ensures seamless table adjustments.
The advantages of a floor standing drill are often overlooked; the Axminster Professional AP25FD won’t take up your valuable bench space, which may be at a premium in your workshop.
Please note, if you require an EU plug, please ensure you purchase 113504
Overall L x W x H 750 mm x 430 mm x 1,650 mm
Power 750 W
Rating Frequent Use
Table Size 345 mm x 345 mm
Table Tilt 45 - 0 - 45
Chuck Capacity 1 mm to 16 mm
Chuck Type keyless
Throat Depth 216 mm
Plug Fitted UK 3 pin plug
Web Attribute Set Drilling Machines
EAN Barcode 5052511136353
This is a Two-Person Large Delivery service. A two-person carrier dedicated to delivering larger and heavier consumer goods into your room of choice; whether in the home (including garden and garage) or at a business address. The carrier will inform you of your delivery options.
  • UK Mainland - £70
