The Axminster Professional AP25FDVS Floor Drill 230V is a versatile and highly accurate machine, perfect for both wood and metal workshops. It offers many functions typically found on more expensive drills, providing excellent value for its price.
Key features of the AP25FDVS Floor Drill include its variable frequency drive: electronic variable speed supplied via an inverter with two speed ranges. This allows you to easily change speeds with the simple twist of a knob, whilst ensuring no loss of torque when changing speeds. It also includes a reverse function, making it ideal for tapping tasks.
This impressive floor drill boasts laser point cross hairs and a built-in LED light for precise drilling. The LED speed readout allows you to easily monitor the speed at which you are operating. Additional benefits of this floor drill include a rack and pinion table adjustment for quick and easy adjustments, multi-vee type belts for maximum grip and low vibration, and a foot switch for easy stopping when both hands are in use. The large cast iron table with a polished finish provides a strong and rigid work surface, and the quality 1-16mm keyless chuck allows for quick and easy changing of drill bits.
Overall, the Axminster Professional AP25FDVS Floor Drill 230V is a reliable and efficient choice for any workshop.
