{"product_id":"axminster-professional-ap300lf-300kg-lifting-table","title":"Axminster Professional AP300LF 300kg Lifting Table","description":"\u003cp\u003eThe AP300LF Lifting Table is designed to provide a versatile and flexible work surface for your workshop. The tabletop measures 1100 x 600mm and can support up to 300kgs, making it suitable for a wide range of woodworking projects or other tasks. As well as using it as a tabletop, you can also customise the lifting table with your own bench top – wooden or otherwise – dependent on your task; you could also use it as an MFT-style table, by fitting an appropriate bench top. The 18mm birch plywood top has a black waterproof coating on one side and a black anti-slip finish on the other.\u003c\/p\u003e\u003cp\u003eEquipped with two braked wheels, the AP300LF offers stability and ease of movement. The easy on and off brake switches can be operated by foot, for convenience and safety. The hydraulic pump allows for safe lifting, with the ability to incrementally increase the height by foot operation. By lifting the pump handle, the table can be steadily lowered, ensuring the safety of your work.\u003c\/p\u003e\u003cp\u003eThe table's height can be adjusted from 45cm at its lowest to 106cm at its highest, offering flexibility for different working heights. Additionally, the handle makes it easy to move the machine around your workspace. The AP300LF mobile lifting table is an essential tool for any woodworker looking for a reliable and adaptable work surface.\u003c\/p\u003e","brand":"Axminster","offers":[{"title":"Default Title","offer_id":54118535725403,"sku":"112137","price":749.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/112137_xl.jpg?v=1789784675","url":"https:\/\/www.axminstertools.com\/products\/axminster-professional-ap300lf-300kg-lifting-table","provider":"Axminster Tools","version":"1.0","type":"link"}
