{"product_id":"axminster-professional-ap3600b-bandsaw-230v","title":"Axminster Professional AP3600B Bandsaw 230V","description":"\u003cp\u003eThe AP3600B is a modern and capable bandsaw, offering robust build quality alongside impressive cutting power.\u003c\/p\u003e\u003cp\u003eWith a generous 360 mm depth and 420 mm width of cut possible, it also features a large 485 mm x 560 mm cast iron table. The table is engineered with a double trunnion table support, making it ideal for supporting large pieces of timber with ease. The powerful 2.5kW motor means you can easily handle big cuts, as required in a demanding workshop.\u003c\/p\u003e\u003cp\u003eThe bandsaw is supported by a solid steel tubular frame which limits vibration. It comes supplied with a rigid T-style, easy glide Hi \/ Lo rip fence for highly accurate cuts. The cast iron blade wheels are fully balanced, reducing vibration further as well as reducing any fatigue from use.\u003c\/p\u003e\u003cp\u003eYou can rest assured that this machine meets all safety requirements: it features a key switch for extra safety when away from the machine, as well as an emergency stop switch. Dual dust extraction ports provide efficient methods of dust extraction to keep your workshop clean and dust free.\u003c\/p\u003e\u003cp\u003eSet up is a breeze; premium blade guides and a quick release blade tension lever make changing or adjusting your blades quick and easy. With levelling feet, you can get your bandsaw perfectly aligned in the workshop. Heavy duty metal handwheels mean your machine will remain in service longer.\u003c\/p\u003e\u003cp\u003eSupplied with a 3\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e x 3 TPI blade.\u003c\/p\u003e\u003cp\u003eN.B. This Machine requires a 16amp supply and it's recommended that a C Type breaker is used, if you are unsure please contact a qualified electrician.\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003ePlease note, if you require an EU plug, please ensure you purchase 113776\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e","brand":"Axminster Professional","offers":[{"title":"Default Title","offer_id":54118499254619,"sku":"109967","price":1599.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109967_xl.jpg?v=1789782851","url":"https:\/\/www.axminstertools.com\/products\/axminster-professional-ap3600b-bandsaw-230v","provider":"Axminster Tools","version":"1.0","type":"link"}
