{"product_id":"axminster-professional-ap460ds-460mm-drum-sander","title":"Axminster Professional AP460DS 460mm Drum Sander","description":"\u003cp\u003eBuilt for demanding workshops, the Axminster Professional AP460DS 460mm Drum Sander is excellent for board, panel and frame sanding.\u003c\/p\u003e\u003cp\u003eIt has a robust fixed-head configuration, so unlike traditional open-ended models, the fixed drum head enhances the structure and the overall heavy duty design provides excellent stability and enhanced machine rigidity.\u003c\/p\u003e\u003cp\u003eThe open ended design allows for a sanding capacity of up to 920mm with a double pass, or 460mm in a single pass - ideal for wide panels and larger workpieces. The sanding thickness capacity is between 5 - 100mm.\u003c\/p\u003e\u003cp\u003ePowered by a quiet 1.5kW motor through twin Poly V-belts, it delivers efficient torque transfer and reduced vibration for smoother operation. It has variable speed, so you have full control over the conveyor. The feed system features a cloth-backed abrasive conveyor belt running over a precision ground cast iron bed, adjustable from 0 to 4 m\/min to suit your material and finish requirements. The bed can be adjusted in height and allows for precise sanding thicknesses to be achieved. The self-cooling aluminium drum minimises heat build up and extends the life of the drum and abrasive.\u003c\/p\u003e\u003cp\u003eThe bed measures 460mm x 465mm and is supported by four sturdy columns to ensure accuracy and minimise vibration. It is synchronised via a chain-driven mechanism for consistent height adjustment. A depth scale is also included for easy adjustment of thickness.\u003c\/p\u003e\u003cp\u003eThe 100mm precision balanced sanding drum is aluminium to ensure accuracy and to limit vibration.\u003c\/p\u003e\u003cp\u003eDust extraction is supported via a 62mm outlet. While a collection bag is included, we recommend pairing the sander with an extractor offering a minimum airflow of 795 m3\/hr for optimal performance.\u003c\/p\u003e\u003cp\u003eA storage cabinet is also included; a perfect space for all your loadings and conveyor belts.\u003c\/p\u003e","brand":"Axminster Professional","offers":[{"title":"Default Title","offer_id":54118669975899,"sku":"113350","price":1599.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/113350_xl.jpg?v=1789790911","url":"https:\/\/www.axminstertools.com\/products\/axminster-professional-ap460ds-460mm-drum-sander","provider":"Axminster Tools","version":"1.0","type":"link"}
