The Axminster Professional AP460WL Woodturning Lathe is a medium-sized, floor standing machine designed to handle a wide range of turning projects with ease. Versatile, solid, and intuitive, it offers the control and reliability needed for both developing and experienced turners.
Its heavy cast iron construction provides 187 kg of mass, ensuring excellent stability and minimising vibration for smooth, controlled results, even when working with large or unbalanced timber.
With 610 mm between centres and a 460 mm swing over the bed, the AP460WL woodturning lathe is well suited to both spindle work and bowl turning. It comes supplied with a 410 mm bed extension and a 220 mm tool rest extension, increasing its capacity for larger projects such as platters and bowls.
The headstock swivels through 180° and features multiple locking positions for improved access during bowl turning. A sliding headstock allows outboard turning at the end of the bed, making it easier to work on larger pieces. The tailstock can also be swung away, providing better access for hollowing or outboard work. In addition, 24-position indexing supports decorative and segmented turning.
A powerful 1.5 kW motor delivers consistent torque across the speed range, including at low speeds, ensuring smooth performance in all conditions. Electronic inverter-controlled variable speed, combined with dual belt ratios, allows precise adjustment for both delicate work and larger, out-of-balance pieces, with speed ranges of 0-1,350 rpm and 0-3,500 rpm.
For added convenience, the magnetic control unit can be positioned anywhere on the lathe bed or headstock. It features clearly arranged on/off buttons, a speed control dial, and a forward/reverse switch, allowing easy operation from wherever you are working.
Integrated tailstock storage keeps essential tools close at hand, helping maintain an efficient and organised workspace.
The lathe features an M33 x 3.5 mm ASR spindle, compatible with all standard M33 x 3.5 mm threaded chucks and accessories. The ASR system includes a safety groove, designed for use with compatible fittings and a locking ring to ensure secure operation in reverse. This feature is optional for general turning.
The AP460WL Woodturning Lathe provides excellent capacity, performance and turning capability. It's a robust lathe that can grow with your skills and handle demanding projects with ease.
Supplied with 100mm, 200mm and 300mm tool rests, 220mm tool rest extension, 150mm faceplate, 4-prong drive centre, live tailstock centre, swing away tailstock and a 410mm bed extension.
Please note, if you require an EU plug, please ensure you purchase 113776
Overall L x W x H 1,528 x 500 x 1,240 mm
Power 1.5 kW
Rating Frequent Use
Web Attribute Set Woodturning Lathes
EAN Barcode 5052511142224
  • UK Mainland - £70
