{"product_id":"axminster-professional-ap940dds-drum-sander-415v","title":"Axminster Professional AP940DDS Drum Sander - 415V","description":"\u003cp\u003eThe AT940DDS twin drum finishing sander is intended for large professional workshops. Power is supplied by a 5.5kW(415V, 3ph) for the sanding drums and a 190W for the conveyor belt drive.\u003c\/p\u003e\u003cp\u003eThe 150mm diameter drums are precision machined from aluminium castings. The abrasive is wound spirally around the drums and securely held by wedge clamps. Coarser abrasive on the front and finer on the rear. There is a very accurate setting system for the rear roller, allowing easy adjustment to accommodate the different grades of abrasive. Three pressure rollers maintain contact between the work and the conveyor belt. This ensures that the work is held in close contact with the belt, giving safe operation and a uniform thickness to the finished work.\u003c\/p\u003e\u003cp\u003eA full width stop bar on the front of the machine can be reached from almost any position, enabling the machine to be stopped quickly.\u003c\/p\u003e\u003cp\u003eThe AP940DDS will handle thicknesses between 1mm and 133mm, adjustment is via a handwheel. A digital read-out scale allows accurate settings. Twin 100mm dust ports provide efficient dust extraction. This solid and dependable machine that can easily handle high volume throughput of a professional workshop.\u003c\/p\u003e\u003cp\u003eMachine supplied with two abrasive loadings (80 grit and 100 grit).\u003c\/p\u003e\u003cp\u003eN.B. Drum sanders are intended to be used with already planed and thicknessed material. Overall a planer\/thicknesser is meant to dimension timber, the drum sander to finish it.\u003c\/p\u003e\u003cp\u003eN.B. 16A supply is required, (Fitted with red 16A plug 415V 3 pin, E + N). Please ensure that your workshop electricity supply is adequate. If unsure, seek advice from a qualified electrician.\u003c\/p\u003e","brand":"Axminster Professional","offers":[{"title":"Default Title","offer_id":54118430605659,"sku":"107639","price":6500.0,"currency_code":"EUR","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/107639_xl.jpg?v=1789779483","url":"https:\/\/www.axminstertools.com\/products\/axminster-professional-ap940dds-drum-sander-415v","provider":"Axminster Tools","version":"1.0","type":"link"}
