This precisely CNC machined reducing bush is made to take the bore diameter of an Axminster Professional CBN grinding wheel down to 18mm in order to fit the CBN wheel to a bench grinder with an 18mm diameter shaft.
Made in Britain Yes
Intended Use Allows fitting CBN wheel to bench grinder with 18mm shaft.
Web Attribute Set Bench Grinders Accessories
EAN Barcode 5052511099313
