This table insert fits the AP254SB Professional Saw Bench. It is required when using a dado blade, replacing the standard insert. The slot is 25mm wide to accommodate the dado blade. It is used with the saw blade set at vertical only. Made from aluminium.
Axminster Professional
Axminster Professional Dado Blade Table Insert For AP254SB
| Web Attribute Set | Saw Bench Accessories |
| EAN Barcode | 5052511131471 |
