This kit is supplied with the Axminster Professional AP250FSG Flexi Shaft Grinder and the HC120 Chisel Style Handpiece.
The Axminster Professional AP250FSG Flexi Shaft Grinder is a compact, high-performance tool designed for precision work across a wide range of materials. Whether you're engraving, cutting, drilling, grinding, carving or polishing, this versatile grinder handles wood, glass, leather, stone, and more with ease. Its robust construction ensures long-lasting durability, and its lightweight, portable design makes it easy to transport and store - perfect for those working across multiple locations or with limited bench space.
Engineered for precision and control, it features a high-torque, low-noise DC24V brushless motor that maintains consistent performance even at low speeds. The built-in variable speed adjustment and RPM tachometer allow you to fine-tune your settings and record them for future use, while the forward/reverse switch enhances flexibility during operation. A foot pedal provides instant start/stop control, giving you hands-free operation and greater precision - especially useful for intricate or repetitive work.
With its enhanced performance and user-friendly features, the AP250FSG is a valuable addition to any workshop.
With the Flexi Shaft Grinder, comes the Axminster Professional HC120 Chisel Style Handpiece. It's a reciprocating power chisel attachment with an ergonomic grip and unique mechanism, delivering twice the reciprocating movement of traditional handpieces. For optimal performance, it operates best between 5,000–8,000 RPM in forward rotation, making it ideal for detailed carving and chiselling tasks across a variety of materials.
