This kit is supplied with the Axminster Professional AP250FSG Flexi Shaft Grinder and the HC110 Chuck Style Handpiece.
The Axminster Professional AP250FSG Flexi Shaft Grinder is a compact, high-performance tool designed for precision work across a wide range of materials. Whether you're engraving, cutting, drilling, grinding, carving or polishing, this versatile grinder handles wood, glass, leather, stone, and more with ease. Its robust construction ensures long-lasting durability, and its lightweight, portable design makes it easy to transport and store - perfect for those working across multiple locations or with limited bench space.
Engineered for precision and control, it features a high-torque, low-noise DC24V brushless motor that maintains consistent performance even at low speeds. The built-in variable speed adjustment and RPM tachometer allow you to fine-tune your settings and record them for future use, while the forward/reverse switch enhances flexibility during operation. A foot pedal provides instant start/stop control, giving you hands-free operation and greater precision - especially useful for intricate or repetitive work.
With its enhanced performance and user-friendly features, the AP250FSG is a valuable addition to any workshop.
With the Flexi Shaft Grinder, comes the Axminster Professional HC110 Chuck Style Handpiece. Featuring excellent concentricity and a grooved, non-slip grip, it's stable and comfortable to use - even during extended sessions. This handpiece is compatible with tools and drill bits ranging from 5/64
When paired with the AP250FSG, the HC110 enhances control and versatility, allowing users to perform engraving, drilling, grinding, and polishing tasks with confidence. Whether you're a professional craftsperson or a dedicated hobbyist, the HC110 is a reliable and adaptable choice for precision work.
