This kit is supplied with the Axminster Professional AP250FSG Flexi Shaft Grinder and the HC130 Collet Style Handpiece.
The Axminster Professional AP250FSG Flexi Shaft Grinder is a compact, high-performance tool designed for precision work across a wide range of materials. Whether you're engraving, cutting, drilling, grinding, carving or polishing, this versatile grinder handles wood, glass, leather, stone, and more with ease. Its robust construction ensures long-lasting durability, and its lightweight, portable design makes it easy to transport and store - perfect for those working across multiple locations or with limited bench space.
Engineered for precision and control, it features a high-torque, low-noise DC24V brushless motor that maintains consistent performance even at low speeds. The built-in variable speed adjustment and RPM tachometer allow you to fine-tune your settings and record them for future use, while the forward/reverse switch enhances flexibility during operation. A foot pedal provides instant start/stop control, giving you hands-free operation and greater precision - especially useful for intricate or repetitive work.
With its enhanced performance and user-friendly features, the AP250FSG is a valuable addition to any workshop.
With the Flexi Shaft Grinder, comes the Axminster Professional HC130 Collet Style Handpiece. Slim and precision-focused, the handpiece accommodates a variety of accessory sizes - 3mm, 6mm, 1/8, and 1/4 - by using interchangeable collets, making it a flexible choice for detailed grinding, polishing and carving tasks. Its streamlined design ensures excellent control and accuracy, making it ideal for users who require a reliable and adaptable handpiece for fine work across multiple materials.
Rating Frequent Use
Corded or Cordless Corded
Cable Length 1.5 m
Motor Power 250 W
Plug Fitted 230V - UK BS89/13 13A Type G (2P+Earth)
Web Attribute Set Flexible Drive Units
EAN Barcode 5052511144716
