These are replacement or spare bobbin spindles for the Axminster Professional AP152OVS Bobbin Sander. They will also fit the Axminster Trade AT152OVS and Jet JBOS5 bobbin sanders. Whilst it is highly unlikely you will need a replacement, unless through loss, having a spare spindle allows you to mount different grit sleeves. Changing the spindle rather than the bobbin is quicker and easier than changing the sleeve when sanding with different grits and also extends the useable life of the sleeve.
Diameter 6 mm
Web Attribute Set Sanding Machine Accessories
EAN Barcode 5052511128853
