Axminster Professional
Axminster Professional SD200SM Spindle Moulder 230V
SKU: 113328
£2,999.98
£2,499.98 Excl. VAT
£70 Large Delivery within 14 working days*.
  • Spindle moulder built to tackle moulding and profiling tasks with ease
  • Precision, cast iron bed for stability and reduced vibration
  • Robust 3kW motor with four speed settings
  • Easy lock spindle tilt mechanism for varying cuts
  • Sliding table to enhance material handling and precision
  • Heavy gauge aluminium extruding fence
Built to tackle moulding and profiling tasks with ease, the Axminster Professional SD200SM Spindle Moulder delivers excellent results every time. Featuring a precision ground cast iron bed, it is stable and vibration free, resulting in accurate machining and long term durability.
With a robust 3kW motor, the 30mm spindle offers four speed control: 1,400, 3,500, 6,000 and 8,000rpm. This allows you to match the cutter speed to your material and project; from delicate moulding blocks to large tenon cutters up to 200mm in diameter. The spindle provides a total height above the table of 120mm, with a usable spindle height of 80mm, offering excellent versatility for a wide range of profiling and joinery operations. The easy lock spindle tilt mechanism enables smooth and secure tilt adjustments between -5° and +45°, making complex angled cuts and advanced joinery work a breeze. There is a stop set at 0° vertical, which can be withdrawn to allow the spindle to tilt forward by +5°. The maximum spindle travel is 125mm.
The 1,200mm sliding table comes as standard. It enhances the material handling and precision, especially when working with larger stock. The heavy gauge aluminium extruded fence and two cast aluminium repeat stops ensure consistent results and deliver efficient repeatability with every pass. This particularly useful for when doing production pieces.
Dust extraction is handled via a 100mm outlet and a minimum airflow of 1000 m³/h is required to keep your workspace clean.
N.B. This spindle moulder requires a 16amp supply and it's recommended that a C Type breaker is used, if you are unsure please contact a qualified electrician.
Please note, if you require an EU plug, please ensure you purchase 113776
Dust Extraction Outlet 100 mm
Overall L x W x H 2,800 x 1,000 x 1,500 mm
Power 3.0 kW
Rating Frequent Use
Table Height 890 mm
Table Size 1,000 x 1,400 mm
Min Extraction Airflow Required 1,000 m³/hr
Sound Power Level LwA [Uncertainty K] 90 dB(A)
Sound Pressure Level LpA [Uncertainty K] 100 dB(A)
Plug Fitted UK 16A Plug
Web Attribute Set Spindle Moulders
EAN Barcode 5052511142491
This product is classified as a Large Delivery product and will normally be delivered within 14 working days.
This is a Bespoke Large Delivery service. Our team will contact you upon completion of your order to discuss carrier options and arrange a delivery date to suit you.
  • UK Mainland - £70
