{"product_id":"axminster-professional-sd2080ce-cyclone-dust-collector-230v","title":"Axminster Professional SD2080CE Cyclone Dust Collector 230V","description":"\u003cp\u003eDesigned for large workshops where air quality and efficiency is key, the Axminster Professional SD2080CE Cyclone Dust Collector delivers excellent performance with a range of smart features.\u003c\/p\u003e\u003cp\u003eCyclone dust extractors efficiently separate larger waste from fine dust before it reaches the fan, allowing the fan to maintain constant speed and suction performance. Heavier waste collects in one container, while finer particles gather in another, helping to reduce the filter load. The cyclone separation system feeds into a generous 175 litre collection drum, which features a quick release mechanism and a clear display window so you can monitor fill levels at a glance.\u003c\/p\u003e\u003cp\u003eThe powerful 2.2kW motor drives the lightweight impeller, delivering an impressive airflow of 2,080 m3\/hr at 152mm. The impeller reduces noise and energy consumption, while maintaining high static pressure (3,027 pa) for effective extraction across multiple machines.\u003c\/p\u003e\u003cp\u003eThe manual double paddle filter cleaning system keeps the 8m² filter surface operating a peak efficiency, extending filter life and maintaining airflow so minimal downtime is required. The advanced filtration performance captures 99% of particles down to 1 micron, ensuring cleaner air and healthier working environment.\u003c\/p\u003e\u003cp\u003eConnecting multiple machines is easy thanks to the variation of inlet sizes; choose the 200mm inlet, or split down into 3 x 100mm inlets.\u003c\/p\u003e\u003cp\u003eCastors feature on the base, allowing easy positioning and manoeuvrability in the workshop.\u003c\/p\u003e\u003cp\u003eThe Bluetooth RF remote control enables wireless operation, so you can effortlessly switch on\/off from anywhere in the workshop.\u003c\/p\u003e\u003cp\u003eSupplied with a 16A plug, running on 230V.\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003ePlease note, if you require an EU plug, please ensure you purchase 113776\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e","brand":"Axminster Professional","offers":[{"title":"Default Title","offer_id":54118668829019,"sku":"113330","price":1750.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/113330_xl.jpg?v=1789790766","url":"https:\/\/www.axminstertools.com\/products\/axminster-professional-sd2080ce-cyclone-dust-collector-230v","provider":"Axminster Tools","version":"1.0","type":"link"}
