{"product_id":"axminster-professional-sd315ps-3200mm-panel-saw-1ph","title":"Axminster Professional SD315PS 3200mm Panel Saw 1ph","description":"\u003cp\u003eThe Axminster Professional SD315PS 3200mm Panel Saw is a highly versatile machine, ideal for sizing sheet materials, ripping solid timber and producing precise angled cuts. Built with a heavy duty construction, the saw delivers exceptional stability and vibration free performance, ensuring consistently accurate results.\u003c\/p\u003e\u003cp\u003eA large 3,200 x 360mm sliding table, combined with an 800 x 1,330mm extension table, provides excellent support for a wide range of workpieces. The sliding table offers a full 3,200mm travel past the blade, making it easy to handle full-size sheets. The main cast iron table measures 800 × 530mm and, together with the extension, offers ample working space at a comfortable working height of 860mm.\u003c\/p\u003e\u003cp\u003eFitted with a 315mm blade running at 4,500rpm, the saw can cut up to 95mm at 90° and 67mm at 45°, with smooth and precise tilt adjustment from 0-45°. This makes it equally capable of cutting thick boards and carrying out complex joinery work. Power comes from a robust 3kW motor, delivering clean, efficient cuts with ease across a variety of materials.\u003c\/p\u003e\u003cp\u003eThe saw unit and motor assembly are housed within a reinforced steel cabinet, isolating mechanical stress from the cast iron table. This design ensures the table remains flat over time, maintaining cutting accuracy even under heavy workloads. A heavy duty aluminium extruded crosscut fence supports workpieces up to 3,900mm in length and includes two precision machined cast aluminium repeat stops for fast, accurate and repeatable cutting.\u003c\/p\u003e\u003cp\u003eWith a ripping capacity of 1,250mm and a sliding table stroke of 3,200mm, handling large panels is straightforward. A dual-motor system drives a dedicated 120mm scoring blade with a 20mm bore, producing flawless finishes on veneered and laminated panels.\u003c\/p\u003e\u003cp\u003eFor safety and dust control, the SD315PS panel saw is equipped with a fully adjustable overhead crown guard that provides clear visibility of the cutting area while capturing dust at source. A 120mm dust extraction outlet requires an airflow of 850m³\/hr, helping to maintain a cleaner, safer working environment.\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003ePlease note, if you require an EU plug, please ensure you purchase 113776\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e","brand":"Axminster Professional","offers":[{"title":"Default Title","offer_id":54118668566875,"sku":"113324","price":6500.0,"currency_code":"EUR","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/113324_xl.jpg?v=1789790724","url":"https:\/\/www.axminstertools.com\/products\/axminster-professional-sd315ps-3200mm-panel-saw-1ph","provider":"Axminster Tools","version":"1.0","type":"link"}
