{"product_id":"axminster-professional-ultimate-edge-twist-fix-arbor","title":"Axminster Professional Ultimate Edge Twist \u0026 Fix Arbor","description":"\u003cp\u003eThe Polishing and Honing 'Twist \u0026amp; Fix' Arbor allows you to attach a mop, felt wheel or profiling wheel to the Axminster Professional Ultimate Edge sharpening machine. The 'Twist \u0026amp; Fix' arbor is totally unique and offers virtually instant change between types of mops or ones with different compounds etc. It comes in two parts, a carrier with a 12mm shaft and the detachable 'Twist \u0026amp; Fix' mop arbor. The carrier bolts onto your Ultimate Edge sharpening machine (mounting hardware supplied).\u003c\/p\u003e\u003cp\u003eThe Twist \u0026amp; Fix arbor does just that, one twist and it’s locked in place on the carrier. The unique connection allows it to run in either direction of rotation: forward or reverse. The 'Twist \u0026amp; Fix' arbor carries the Ultimate Edge mops and honing wheels. Polishing mops, felt wheels etc should always be used in order, working from coarse to fine compound. With each mop etc mounted on its own 'Twist \u0026amp; Fix' arbor you can change in an instant, ensuring the polishing process is quick, safe and simple.\u003c\/p\u003e\u003cp\u003eAdditional Twist \u0026amp; Fix mop arbors are available as single items or in 3’s.\u003c\/p\u003e","brand":"Axminster Professional","offers":[{"title":"Default Title","offer_id":54118327091547,"sku":"105419","price":51.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/105419_xl.jpg?v=1789775721","url":"https:\/\/www.axminstertools.com\/products\/axminster-professional-ultimate-edge-twist-fix-arbor","provider":"Axminster Tools","version":"1.0","type":"link"}
