Axminster Ramia Clever Worktop
SKU: 114429
£149.98
£124.98 Excl. VAT
  • Portable beech worktop design
  • Integrated carpenter's vice
  • Includes four round bench dogs
  • Block laminated beech construction
  • Suitable for woodworking and DIY tasks
  • Can be clamped or fixed to a work surface
  • Compact and easy to store
  • Lightweight 10kg design
Ramia Clever Worktop is a compact, portable woodworking worktop designed for woodworkers, DIYers and home improvers who need a practical workholding solution without a dedicated workshop. Made from block laminated beech wood, it provides a stable and durable working surface for a wide range of tasks, including planing, sawing, sanding, carving and general household repairs. Lightweight and easy to transport, it can be quickly stored away when not in use.
Equipped with a carpenter's vice and four round bench dogs, the Clever Worktop offers secure and versatile workholding for a variety of projects. It can be clamped to a table using suitable clamps or permanently fixed to a work surface, allowing you to create an instant workstation wherever needed.
The worktop measures 410mm long by 360mm wide and is 30mm thick. Overall dimensions are 560mm x 360mm x 110mm. The front vice measures 360mm x 55mm with a clamping capacity of 130mm. Weighing just 10kg, it is easy to move, transport and store.
Ramia is a respected Czech manufacturer known for producing high-quality woodworking benches and workshop equipment. Combining traditional craftsmanship with practical design, Ramia products are trusted by woodworkers worldwide.
Ideal for hobby woodworkers, DIY enthusiasts and anyone with limited workshop space, the Ramia Clever Worktop provides a convenient and portable workholding solution.
Supplied with a set of Hobby round bench dogs, one small front/side vice spindle and a spindle key.
Overall L x W x H 560mm x 360mm x 110mm
Table Size Worktop length 410 mm
Web Attribute Set Portable Work Benches & Trestles
EAN Barcode 8594072291012
