Axminster Ramia Multi-bench 2000 Workbench
SKU: 114566
£1,899.98
£1,583.32 Excl. VAT
  • Constructed entirely from Beech wood
  • 100mm thick solid worktop
  • Two identical heavy-duty 170mm capacity vices
  • Anti-racking screw-set for precise clamping
  • 54 bench dog holes for versatile workholding
  • Traditional bench dogs included
  • Configurable for left or right-handed use
  • Heavy-duty 135kg construction for maximum stability
Ramia Multi-Bench 2000 Workbench is a premium, American-style woodworking workbench designed to deliver exceptional versatility, strength and precise workholding for demanding workshop environments. Built around a substantial 100mm thick solid benchtop and featuring a flat work surface with no rear tool well, the Multi-Bench 2000 provides maximum usable workspace. Its innovative interchangeable vice system allows woodworkers to reposition the front and side vices within seconds, creating a highly adaptable bench that can be configured for left-handed or right-handed use, with both vices mounted at the front, on the sides, or in a combination that best suits the task.
What sets the Multi-Bench 2000 apart is its unique dual-vice configuration and advanced anti-racking design. Both vices are identical in size and performance, with pre-installed spindle mountings beneath the benchtop allowing rapid vice relocation without complex adjustments. Each vice incorporates a stabilising screw-set that prevents unwanted racking and helps eliminate the risk of vice misalignment during clamping. By adjusting the stabilising screw-set to match the thickness of the workpiece, users can achieve exceptionally secure, accurate edge clamping with consistent pressure. Traditional round bench dogs provide fine adjustment for a wide range of stock thicknesses, while the extensive arrangement of bench dog holes delivers outstanding clamping flexibility for both horizontal and vertical work.
The Multi-Bench 2000 features a worktop length of 1,850mm and an overall length of 2,020mm. The solid work surface measures 650mm wide and sits at a comfortable working height of 900mm. The heavy-duty 100mm thick benchtop provides excellent stability and vibration resistance, contributing to the bench's substantial 135kg weight. Both the front and side vices measure 620mm x 70mm and offer a clamping capacity of 170mm. The workbench includes 54 bench dog holes in the work surface, four holes on each side of the front section, and additional holes within each vice jaw, providing extensive workholding options for components of varying sizes and shapes. Holes in the base also allow secure vertical clamping of larger projects such as doors.
Ramia is a renowned Czech manufacturer specialising in high-quality woodworking benches and workshop equipment. Known for combining traditional craftsmanship with innovative engineering, Ramia products are trusted by professionals, colleges and dedicated woodworkers worldwide. The Axminster Ramia range combines this respected Czech bench-making heritage with the trusted service and support of Axminster Tools.
Ideal for professional furniture makers, cabinetmakers, joiners and dedicated home woodworkers, the Ramia Multi-Bench 2000 is designed for anyone requiring maximum flexibility in their workholding setup. Supplied with four traditional round bench dogs, two front/side large spindles, two large spindle guides, two spindle keys (wrenches) and two stabilising screw-sets to prevent unwanted vice racking and misalignment.
As a special-order item, this workbench is supplied and shipped directly from Ramia to your chosen delivery address.
Overall L x W x H 2,020 mm x 820 mm x 900 mm
Web Attribute Set Woodworking Benches
EAN Barcode 5052511148264
