{"product_id":"axminster-roller-bracket-set-250mm","title":"Axminster Roller \u0026 Bracket Set - 250mm","description":"\u003cp\u003eAt 250mm long, this roller is a convenient size for custom-made material support. For example, fixing a roller on either side of a bench mounted machine to support long lengths of timber when cutting or drilling etc. The roller itself is 250mm long and 35mm in diameter, and is only 280 x 50mm with the mounting bracket. Ball race bearings at either end of the roller ensure smooth free running. The spring-loaded axle makes it easy to remove and replace the roller from the bracket when fixing. The strong steel bracket has mounting holes for screwing to a bench top or a sawhorse etc. The roller can handle weights up to 50kg.\u003c\/p\u003e","brand":"Axminster","offers":[{"title":"Default Title","offer_id":54118262243675,"sku":"103700","price":8.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/103700_xl.jpg?v=1789773206","url":"https:\/\/www.axminstertools.com\/products\/axminster-roller-bracket-set-250mm","provider":"Axminster Tools","version":"1.0","type":"link"}
