Axminster Roller & Bracket Set - 250mm
SKU: 103700
£8.98
£7.48 Excl. VAT
  • 35mm dia x 250mm long, smooth free running roller
  • Provides material support up to 50kg load
  • Smooth, hard chrome plated, will not mark work
  • Use to support long workpieces for bench-mounted machines
  • Create custom designed roller support stands
  • Easy to fix to a bench or sawhorse
At 250mm long, this roller is a convenient size for custom-made material support. For example, fixing a roller on either side of a bench mounted machine to support long lengths of timber when cutting or drilling etc. The roller itself is 250mm long and 35mm in diameter, and is only 280 x 50mm with the mounting bracket. Ball race bearings at either end of the roller ensure smooth free running. The spring-loaded axle makes it easy to remove and replace the roller from the bracket when fixing. The strong steel bracket has mounting holes for screwing to a bench top or a sawhorse etc. The roller can handle weights up to 50kg.
Web Attribute Set Material Support
EAN Barcode 5052511094486
