{"product_id":"axminster-roller-bracket-set-400mm","title":"Axminster Roller \u0026 Bracket Set - 400mm","description":"\u003cp\u003eThis large roller measures 400mm long x 57mm diameter. It has a ball race bearing at either end to ensure smooth free running. The roller and bracket set is an easy solution when looking for extra material support for a saw bench or mitre saw for instance. The spring-loaded axle makes it easy to remove the roller from the bracket. The strong steel bracket has mounting holes for screwing to a bench top or a sawhorse etc. The roller then clips back into the bracket. The large roller has a load capacity of 80kg. With this roller and bracket, you can build and design your own roller stand or fix several onto a workbench for heavy-duty jobs. Smooth rolling, the heavy-duty steel roller is 57mm diameter by 400mm long, overall the unit is 66mm high and 444mm long.\u003c\/p\u003e","brand":"Axminster","offers":[{"title":"Default Title","offer_id":54118260441435,"sku":"103701","price":16.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/103701_xl.jpg?v=1789773199","url":"https:\/\/www.axminstertools.com\/products\/axminster-roller-bracket-set-400mm","provider":"Axminster Tools","version":"1.0","type":"link"}
